The power would come from the light switch, unless I can take a spur from a mains socket in the room above but that means the wall lights would be on the upstairs ring main instead of a lighting circuit. Would this be acceptable or bad practice ?I agree, the lights need power!
However, not having to raggle/chase for the switches does save a lot of time and redecoration.
I’m not sure if it’s just the angle and the lighting in the photo but it seems like the insulation is suffering from a bit of heat damage on two of your blue cables in the back of the switch.
