J
Jimmyb
If I add a rcd to a ring final at the fuse board because im adding extra sockets and moving some other I need to test all old sockets as well right ?? the reason I ask is ive quoted for the job and was discussing with the customer yesterday what I had to do, I saw her tonight at the pub and she said you havnt got the job and when I said about are you getting the same service she said the two other sparky both said that you put an rcd onto the circuit and just test the new work as your not responsible for the old, I mentioned about insulation test and what was involed to make sure there was no problems the rcd would pick up on and she said they mentioned something about unplugging everything before he arrived. Im I the only one that checks all sockets if ive change the cpd
