Discuss Adding to kitchen wiring does cooker circuit need RCD protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all, first post by a new member so apologies for any posting faux pas in advance. (Hopefully this is the correct place to ask this rather long question)
I’m in the process of re fitting my kitchen and was planning on making a couple of minor changes to the wiring installation. All of the fixed appliances in old kitchen were plugged into 13amp sockets mounted under sink, installed before I bought the house, I understand this is technically allowed but I’ve never liked it so Im planning on adding some dp 20 amp switches above worktop level feeding sockets mounted behind appliances. my oven is on its own dedicated 32amp circuit with 6mm twin and earth that has obviously had a cooker control unit replaced with a 13amp 2 gang socket, (also mounted under sink) my new oven will have a 13amp plugtop but I would like to reconstitute the cooker control unit above worktop as a means to isolate oven if needed (I know a 45 amp cooker control unit is not necessary for a cooker plugged into 13amp socket but I’d like the flexibility if I want to upgrade to an oven with a higher draw in the future) anyway, its an old house and walls are all over the place so I’ll be batten and boarding, so any new runs will be affixed to wall behind battens within safe zones. My question/ issue is that doing research on most recent regs it seems to read that any cable not buried deeper than 50mm in a wall or partition need rcd protection? Not a problem with sockets as they are, but cooker circuit is not protected? Do I need to get an rcd fitted(obviously by a pro) or is there another option? I want to do everything by the book and totally respect the advantages of having a pro do all of this work but I’m working to a tinnie tiny budget and have enough experience to do all the work to a high standard myself, although I’m obviously not a qualified electrician or I wouldn’t be asking what is probably a straight forward question ‍♂️. Thanks in advance for any advice offered and any points that my post may bring to mind. Cheers
you need to look at reg.no.522.6.101 or thereabouts regardign cables < 50mm in walls. there are alternatives to RCD, but a RCD/RCBO is an easier option.
Reply to Adding to kitchen wiring does cooker circuit need RCD protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Bit of advise if anyone has time.. I have a customer who brought a new kitchen from wrens. Customer has had the route to the kitsch redecorated...
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
