Discuss Advice on wiring for LED lighting in the UK Electrical Forum area at ElectriciansForums.net
G
Gary Palmer
Hi,
Im after some advice, I recently refurb'd my Kitchen. When the kitchen was re-wired I put in place one circuit with 3 connection points to install a light under each cupboard. This is fine if I wanted standard tubes underneath, however I'd like to fit some LED strip lights, however I now find that most of these are connected via a seperate 'link cable'. I cant use these as my wiring is buried underneath the plaster.
So the only solution I can think of is to wire in a transformer/driver at each connection point (cupboard) in the circuit.
Is there any reason not to do this? or a better way?
Cheers
Gary
generally you would fit the transformers on top of the wall cupboards, with the leads to the lights in the 1/2" cavity behind them. can you dig your cables out above cupboards?
Thanks for all the replies. Looks like I'll go down the three separates route. I have access to the connection points. they were terminated so that I could fit the lights when ready. really I just wanted to make sure there wasn't a problem fitting 3 of these transformers on the circuit OR that there wasn't a better way I wasn't aware of.
Reply to Advice on wiring for LED lighting in the UK Electrical Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
