Discuss Advise on hole cutting - steel consumer unit in the Australia area at ElectriciansForums.net
various methods, I usually fix 2 x 2 galv / plastic / trunkings under/side/top. bush through to existing knockouts, spacing locknut between
This is the method I have seen countless times and advise to use
Depending on the spacing and quantity of the conduits coming through the top,try and pick these up directly,fit 2x2 galv trunking underneath,drilling holes to suit the pipes and the dist board ,bush and locknut with a locknut between to keep the board and the trunking slightly apart
Hi Wassup + Des 56,
I'm trying to visualize this...
So you're cutting the trunking to use as a plate to keep the integrity of the CU ?
IE. attaching the trunking to the CU using bushes and locknuts to non knock out overlapping holes, then drilling the remaining holes regardless of whether the knockouts come out, as you'll be leaving the conduit / plate in situ.
Also, what's the advantage of keeping the board and trunking slightly apart with the locknut between ?
Thanks a lot,
Al
They mean drill holes on one side of the trunking that match your knock outs on the CU. Then cut holes on the other side of the trunking that match the positions of the MI and conduits. you sandwich the trunking between the two, the cables pass through the trunking and then into the CU via the bushed knock outs. It's just so you don't have to have the norse of trying to drill holes between knock outs on the CU. You want to keep the trunking slightly apart from the CU with lock nuts because its a pain to get the lid on the trunking if it's butted up too close to the board.
Right,
I'm with you pennywise,
Thanks for that.
But that's my problem...
It's a damn tight fit as it is and I don't have the extra space for the trunking.
I going to go with UNG's clamp and wood block method.
If a knockout does come out I'll have to attach a plate and re-drill....
I don't recall being taught there was anything wrong with this approach per se, but I'm guessing it'd be ok if the CU integrity and IP standards were maintained... I'll ask elecsa tomorrow.
Thanks for all the replies...
what a nice community !
Al
What I was refering to was not ripping the knockout out but when the hole is cut and the hole cut happens overlap the part of the knockout which is attached to the CU the knockout will come out
You make it sound like it is a certainty that the knockout will fall out I have done this loads of times are never had a problem
It is a certainty if you drill out one of the 'tabs' holding the knockout in place. It wont stay in with only one side holding it. Some knockouts will stay in no matter how much stick you give them, some will fal out if you look at them the wrong way.
Ialso use the 2 x 2 plastic trunking on the top of the CU. It is a very good way of complying with the required IP rating for a horizontal top surface.
Reply to Advise on hole cutting - steel consumer unit in the Australia area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
