You are not required to bond the cable tray that is already pre-installed for you during the AM2.
Metal trunking will generally require an earth if it contains low voltage circuits with continuity to the MET but not necessarily a direct connection to it. Cable tray does not however this is highly debated and you should do some research to enforce your actions if you decide to or not.
So I wont loose any marks if the metal trunking or cable tray is not bonded. I thought though thay any exposed metal part than can become live under fault conditions and easy touched is supposed to be bonded? Or im I wrong?
Not required on the AM2.
All containment it already in place for am2 no need to touch any of it
