Discuss Amazon - Interesting advice for wiring a Sonoff smart switch in the UK Electrical Forum area at ElectriciansForums.net
Shoei
What if I have PME could I just connect it to the earth instead ?
You can report product for false information if you are logged into your account. If enough of us do then maybe amazon will stop selling them, maybe !
I am not an electrician (electronics background), but find reading this site very interesting. The terminology used on that device appears to be American, and is clearly wrong for the UK. Reported on amazon.
What? Using a blue sharpie pen, draw a line from the nearest socket diagonally up to the switch.
not diagonal. sharpie lines should be in prescribed zones, as recommended by sharpie in their manufacturers instructions. DOH.!.
My house needs renovating anyways I will buy a couple, install them as advised and when the house burns down will claim on their PLI. Win Win situation.
Yes, it's helpful to draw a line on the wall as a guide for chasing.
The chase will only need to be small as a 1.5mm single doesn't take up much space. Don't forget to fit rubber grommets to the cable entry holes on metal back boxes.
Gripfill is a quick and easy way to fill both hold the wire in place and to fill the chase in.
A bit late to this: Sonoff are from Shenzhen in China. Their instructions are genereic, and clearly not applicable universally.
Regardless, their products are pretty amazing for their price (check out their "WiFi DIY MINI Smart Switch). However, slight tech issue: see separate thread.
Reply to Amazon - Interesting advice for wiring a Sonoff smart switch in the UK Electrical Forum area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
DIY Advice required. Ive just recently brought a Sonoff T0UK1C wifi smart switch for my Living Room. The existing light switch is ya standard one...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I want to install smart light switch into the wall socket that currently has a normal light switch. The smart switch requires a neutral wire which...
Hi. I am trying to replace a heating timer with a smart switch. The current timer is the type with a dial on the front and 1 to 24 written on it...
