J
John J
So I’ve recently started my level 3 course and I’m doing electrical system designs the one with the hotel extension and pool and cafe block I’ve done question 1 but stuck on all of question 2 some guidance would be appreciated thanks.
Hi all,
Just started doing the 2365-305 assignment myself. As with the above advice given by the experienced/expert members, I'll try and ask one focused question at a time
Is there a website that we can see all of the BS EN 60617 symbols needed for the assignment?
Upvote 0
Upvote 0
Hi on question 1 did you find an example on the internet to use
Likely yes, it's not a hard one to grasp; Find a manufacturer (Fusebox, Wylex, BG), Download/Print the datasheets and use them in your project. Not sure why this is hard for some (not a dig at OP, purely an observation as it's not that first time this has come up)
Upvote 0
I did this in 2018 it was very much like being told to outfit a Travelodge, if you've ever been in one you'd recognise the layout. It's just they've removed all the socket outlets, fused spurs, electric radiators, heated towel rails and lighting on the plans and expect you to do a competent job filling in the blanks.
Upvote 0
Hi, would someone be able to give me some pointers for the attached photo for the c&g 2365 level 3 design assignment.
Am I on the right path, Should I do it something slightly different.
When working out cable lengths from a drawing that has a scale, Do you measure the route as installed to furthest point?
Thx for any help
Upvote 0
The forum is for advice however we will not condone members doing your homework, assignments etc, if you are spoon fed answers then you do not learn, if you do not understand an exam or assignment question then discuss with your tutor, this career direction is reliant on the fact you understand what you are doing and winging it can not only put your life at risk but that of others, if you have a particular question then post your full answer for it and at most we will give you a guiding nudge.
Upvote 0
Thx for any help
You really ought to know the design calculations by this point in the level 3.
As for lengths you want to factor in to tht longest point. Table 7 (iirc) gives preset circuit designs for reference.
If you don't have thr calculation process nailed, put this side, grab s random number generator to get a value for Ib and then work the equations until they stick.
Here's a walkthrough on various cable calculations for design etc. (Credit: @Loki ) Cable Calculations - https://www.electriciansforums.net/resources/cable-calculations.139/
Upvote 0
Hi all, doing my design assignment. Ive done questions 1,2,3 and filled out table 1 as best i could. When it comes to the distribution circuit, im a bit lost. I know it needs a 5s disconnection time but apart from that is there another calculation i should be doing? Also what type breaker should be feeding it? Thx for any help
Upvote 0
Are you on Q4? What distribution circuit?
Upvote 0
John J,
MrBob123,
Electrical Courses
