Discuss Bathroom mirror lights don't work without main light switched on in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pete77
Hi all, apologies if there is a more appropriate forum, I just can't seem to find a definitive answer!
I have 2 bathrooms, each of which has a mains-wired mirror with lights, shaver socket and demister. Downstairs, the mirror lights etc. only work if the main light is switched on. Upstairs, the mirror works independently of the main light.
I'm assuming the latter is the correct setup? i.e. the mirror should work without the main light on. If so, can anyone suggest a likely reason for the downstairs mirror working that way?
Any advise appreciated
P
Well worth signing up to the forum for that calibre of advice! :p
Perhaps I should have asked 'can anyone suggest why it might have been wired like that?' The neighbour's bathroom is wired the same way.
Obviously 'looped' off of the main lighting s/l. Maybe in the light fitting, switch or a hidden junction box.
As for why, you'll have to ask the original installer!
It sounds like someone made a mistake either at 1st or 2nd fix.
Correcting it could be as simple as altering wiring at a switch or may need part of the circuit rewired
Impossible to tell which from here.
Probably when they were fitted the permanent live was not accessible and they could only tap into the switched live to avoid major disruption and damage to the decor.
Hi,
I think it was a stress mistake made by the electrician. The reason for the udesired behavior of lighting downstairs is because: live wire that must be headed to mirror switch is taken from the output terminal of the previous main switch instead of taking it directly from live feeding the entire bathroom lighting. On the surface mounted box in which the main switch takes place, notice the output terminal (screwdrive junction) it must contain 2 red wires. If you could identify which of refers to the mirror, detach it from where it is and plug it to the other terminal. This is while assuming you have SPST switches.
Dj
Reply to Bathroom mirror lights don't work without main light switched on in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, I'm an apprentice electrician and have been doing some basic work on my bathroom with what I've picked up on site. I've split the mains...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I have a quick query. I have a bathroom mirror with built in shaver socket and isolating transformer. However, it is not switched and is...
8K
