Guys
Quick question regarding moving my bathroom pull cord to a switch.
I was measuring my bathroom zones as per 7671, and I would like to put a light switch 0.73m outside of zone 2, the problem is I could not see anything relating to a light switch in particular only a socket, And pull cord switches.
All the circuits are RCD protected.
No it only applies to zones 1 and 2 but outside the zones you have to take Reg 512.2 into consideration.
Yep I'm very aware of that, but no specific IP rating for outside zones is stipulated. IPX4 is suitable for splashes, but splashes are unlikely to be encountered outside the zones.
Collection of moisture through condensation is more likely the culprit 730mm outside of zone 2. Appx 5 defines this as code AD2 which is satisfied by IPX1 or IPX2.
So a plain whit Mk light switch will suffice. I don't fancy on of those outdoor grey switches.
My worry is wet people with wet hands walking from the shower and switching the switch.
Granted you aren't in the bath or the shower but even so..
So pull cords are safer. Then again if the lighting is on an RCD your protected.
I did consider that, however the wettest I think hands will be is damp.
So I'm not expecting water to be running off hands.
That sounds reason enough to put it outside to me, you know, for a laugh.
Did you mean Czech girls or cheeky girls ? If you meant cheeky girls do you mean the cheeky girls ? and were the cheeky girls Czech ?
Czech girls what websites have you been visiting apart from this one then Andy?
Your in the shower in the evening and the light goes off (blown bulb maybe) the first thing somebody would do is get out and try the switch. Probably dripping wet. So it can happen so if a wall switch is a must then I'd have it RCD protected. which means at worst you get a little zap.
What about something like this:
Bathroom Sensor Switch | Tile Switch | Touch Switch PIR Movement Switch - http://www.sensor.co.uk/switches/bathroom_switch/
It is bl^^^dy RCD protected, he said it was in the OP. I wish folks would read things......
I didn't say it wasn't. I do think its safer to re-iterate RCD protection when talking about plate switches in bathrooms. You can't be sure the whole thread will be read in the future when another poster is searching for answers.
Never assume an rcd is God's gift for you not dropping dead from an electric shock.
Ah but touch it again and you may just be brought back.
I think a switch would have to be absolutely drenched in water, dripping down it, in order to get a shock. That is obviously why the 0.6M distance is stipulated, so the shower head, for example, won't be directed at it. I don't think a person, however wet, would be in danger from operating the switch, personally.
I mean wet from the shower, not wet generally.
I agree but is the accessory going to be effected but water splashes, yes you can't guarantee it won't. My opinion is to put it outside the room or fit a pull switch.
Maidenhead
Bathroom zoning question
Pauldicker,
DPG,
