docka
I actually had an enquiry! The roof's a little unusual though so i'm looking for a decent black framed mono 250W module that will allow mounting rails to be around 600mm apart without voiding warranty and with a good (5000Pa +) mechanical resistance.
To save me trawling through any more specs, anyone know of one off hand?
Thanks in advance...
Ie a 1600mm ish module that will allow an overhang of around 500mm on the long side when mounted portrait...
think you'll struggle with that.
Hyundai are about the most solidly built black framed panels of that size I know of, and I'd probably consider putting them with 500mm overhang on situations with low wind and snow loading, but not if 5000pa loading is needed.
can you not do a cruciform mounting system to get the mounting rails in the right place?
Thanks Gavin i'll look at the Hyundai specs.
However, a cruciform system may be in order it's just they dont look that great do they...
Even a semi-integrated system such as the Intersole SE by Renusol may be the answer albeit costlier...
Black 250Wp Module required with narrow mounting points
docka,
docka,
