P
pingu
Hello forum electricians.
Firstly just to explain I was an electrician but have not re-certified to 17th edition or worked as an electrician for a very long time. So that's me.
Anyway I recently had the kitchen upgraded and decided to do the electrical work myself refreshing and verifying additions just to make sure. I transpired the electrics were a death trap with spurs everywhere but sorted all that out.
Last job was to upgrade the CU. Low and behold borrowed neutral issue.
As I see it I have two options.
1 Put upstairs and downstairs lighting circuits into the same MCB. OK in an ideal world I would like two lighting circuits and this may be a temporary fix until I redecorate the hall at which time I could run a separate neutral.
2 Run a separate neutral now.
The issue I see with running a separate neutral in my installation would be that in the hall I have the downstairs toilet, the hall and landing on a three gang switch. On the landing I have the bathroom and the landing on a two gang switch.
If I run a separate neutral should I separate the switches on the landing as if you isolate the downstairs lighting there would still be the upstairs bathroom light circuit live in the same back box. From recollection you cannot have two separate circuits in the same box I would need a common point of isolation.
