I can't see the harm in adding a DIY forum here, it would save a lot of grief, we would all be prepared and there would be less slating IMO, in fact we would be concerned for the H&S of the poster and be more subtle.
Yeah, but the problem would be that many wouldn't consider themselves DIYers
I am apprenticed qualified.
An isolator is the best option but thu charge :(
Do tails "need" to be upgraded? They are 5 metres long and go through the roof space into a cupboard in the hallway (property is a flat)
Fuse switch ?
Whazza you really are opening up a can of worms with this one, do you feel comfortable doing this con unit swap my advice would be if you don't, then don't do it. No shame in saying your not ready to undertake a job.
Well if your apprenticed qualified (Is that actually a word) what did your gaffer do?
Or did they never need to isolate the supply????
Changing the consumer unit is not too big of a Job, but as I don't deal with domestic installations I was after a bit of advice.
All I was querying was what people do with removing the main fuse + upgrading the tails as my domestic experience isn't huge.
I know many electricians who just pull it out and many that get Western Power to put in an isolator. Obviously an isolator is the best option.
Nothing wrong with asking for a bit of advice, if no one asked questions then no one would be where they are now
What does "subtle" mean??? :thinking:
- - - Updated - - -
Although it is an easy process to remove it, incorrect removal can be either fatal due to the high voltage etc, or end up with a broken fuse or carrier and then you will need to pay them to come and fix it whilst trying to explain to them why you removed it in the first place. This is why they wired with a security seal as to attempt to prevent unauthorised removal. If you remove the fuse, you are in breach of your contract with the supply company and have commited a criminal act.
Although its straight forward enuogh, unless it comes out in one go you are likely to run into problems. I will not touch the main fuse as would rather not have the hassle. If you are going to do it, my advise would that, you shouldnt, but if you do, ensure theres NO LOAD, so switch the consumer unit off, then take firm hold of it and pull it out in one smooth but swift movement. Thats my thoughts anyway.
Personally if i ever had to for whatever reason have to remove one, I would take all measures needed to prevent killing myself, so would ensure I was wearing insulated shoes, appropriate rubber gloves, and some form of mask, then hope for the best. I know this is more than likely over kill, but id rather not do it, just incase it breaks it, as you will not be able to fix it without third party help.
Oh and when you do put it back in, try and get the pins to connect at the same time, and push it in firmly in one go, dont mess about with it.
Best of luck!
Having spent many years working in the DNO and witnessing first hand the results of a "flash over" at a cutout posts like this sends shivers down my spine, for everyone's sake fella keep your mouth shut when you don't fully understand the topic you are talking about
