M
MDJ
Hi everyone,
I'm sure this topic has been risen plenty of times.
I'm a qualified electrician and I am going to replace a consumer unit for a relative. I am not registered with NICEIC or NAPIT so will be getting it tested by the council.
Can anyone explain the procedure for removing the main fuse as it is sealed?
I know it will never be checked but would just like to know what everyone does. It's absolutely crazy that a qualified electrician is meant to call western power to remove the seal or replace the seal, especially if they have a business to run!!
Thanks in advance.
As you intend to get building control involved and they will send someone to inspect your works, I strongly recommend you be very careful how far you go in regard to this situation, regardless of your experience, if someone comes to look at your work you may get into trouble if you are reported for installing new tails to the meter, beware in this case IMO.
