Hi everyone,
I'm sure this topic has been risen plenty of times.
I'm a qualified electrician and I am going to replace a consumer unit for a relative. I am not registered with NICEIC or NAPIT so will be getting it tested by the council.
Can anyone explain the procedure for removing the main fuse as it is sealed?
I know it will never be checked but would just like to know what everyone does. It's absolutely crazy that a qualified electrician is meant to call western power to remove the seal or replace the seal, especially if they have a business to run!!
Thanks in advance.
As you intend to get building control involved and they will send someone to inspect your works, I strongly recommend you be very careful how far you go in regard to this situation, regardless of your experience, if someone comes to look at your work you may get into trouble if you are reported for installing new tails to the meter, beware in this case IMO.
Not wishing to sound ---- here, but I was making a general reference to what most people would class as a "high" enough "voltage" to kill you.
Or as Tidy Boiler often tells me: "Silence is golden but Duct Tape is silver". ............. DON'T ask !!!!
In my new job I have been given training in pulling the main bullet. Never in all my years have I ever been so ---- scared after seeing the consequences (photos and personal testimony). The electrical explosion that occurs on short circuit on a faulty service head is simply something that I would never want to experience, even with full PPE.
I think we need to be factoring in a DNO callout to at least provide safe isolation, but preferably examination of and fitting of an isolator, in our prices.
should i be laughing so much at this thread, does that make me a sad person
No not at all LOL, but considering the OP is getting building control involved, advising him to cut the seals is like sticking a one legged man into an --- kicking contest haha
Its also highly unlikely that anything will ever come of it, if you do pull it out and put it back as most people do, but its more the fact that it might break or not come out nicely when you do that puts me off. Oh and dont forget to put a protective thing in the slot to prevent accidentle contact. Not sure where you buy the red thing from though.
Talking from experience are we? Advising those less experienced. Advice coming your way....look left, look right, look left again and put the tin hat on.
There really is a lot of talking bull ox here sometimes, the question is this, are you a "competent person" If so, you are going to a customers house to replace a consumer unit, to do that without isolating the supply presents a real danger to yourself, and to the customer. It is therefore your duty to isolate the supply by whatever means available in order to work safely. If that means removing the cutout fuse, remove it. One proviso here, and it has been discussed in other threads, I would be wary of touching some of the older cast iron/porcelain fuse set ups unless they are in top nick! IT IS NOT ILLEGAL TO REMOVE THE FUSE! there, I've said it. We used to quote the "electricity supply act 1921" In case of danger any competent person may remove the cutout fuse in order to render the installation safe. What you gonna do if you walk through the door and there is magic smoke escaping from the meter/consumer unit/tails etc? In 50 years on the job I have removed thousands, done the necessary work, replaced them, and wound the previously carefully cut seal wire back in position. If you have ever seen a supply authority "engineer" remove a seal with a pair of uninsulated tin snips big enough to cut a transatlantic cable you would realise that all they want is the fastest way out of the door. The seal is there to prevent naughty consumers abstracting un-metered juice (always presuming it is there at all). Competent person means just that. You DO NOT have to be a scam member, but you will be expected to supply LABC (elec) with a completed test cert which you can also do without joining the scams. I have my fireproof underwear on, no pedants need reply. Happy new year to all engineers everywhere, onward and upward lads and lasses!
lol they didn't teach mr fix it that 230v is not a high voltage on the Electrical Trainee course
Good spot Glenn
You can do what you like, just don't expect us to advise a spark who is getting building control in to check his work to cut meter seals, whether it goes on or not is regardless, and I still want to know what a thingy is???
