Discuss BT Socket - having a blonde moment! in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Ok, got a client who want me to connect a BT "extension" into the back of the socket in their house. The "extension" cable is of the type you would buy off the shelf and has already fitted the socket on one end and the plug on the other - both moulded into position so its not possible to check the colours and connections used!.
The "BT" house socket is connected thus:
1. nc
2. Blue/white band
3. Orange/white band
4. nc
5. White/blue band
6. nc
The "extension cable has the following colours
Red
Blue
Green
White
so the question is in what order do I connect the cable shown in the picture?
Many thanks.....
(being very blonde today)
strip and separate the cores. plug into socket. the line pair will have 48V d.c. on them.
So I'm thinking that:
1. nc
2. White
3. Green
4. Blue
5. Red
6. nc
OK, too late. Just seen MarkieSparkie's response so a BIG thanks all.
you only want 2 and 5 connected. red and white, either way round. polarity couls be an issue with broadband. if so, switch em round
Reply to BT Socket - having a blonde moment! in the UK Electrical Forum area at ElectriciansForums.net
I have old & new BT wires that I am in need of help with please. The old wiring coming directly into the house hidden inside a grey plastic box...
Hi All, We've recently moved to a new build where the HMDI cable for the TV etc. are pre-fitted in the cavity of the wall. One end of the HMDI...
My pir cables are red+ Black - Yellow blue alarm or relay Yellow green tamper However one has different colours Blue Blue white Orange Orange...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
