I recently had reason to look at the switch in my garage that controls the outdoor garage lights. This picture shows how the switch is wired and I haven't the foggiest idea of why a neutral wire runs to the switch. Note that this wiring was done by the house's builder about 20 years ago. (Note that the on/off note shows voltage measurements I took.)
Simple question: Can I replace this switch with a two port switch, i.e., one that does not connect with the neutral wire, and expect the light to keep working?
Possibly trickier: If you could explain the purpose the the neutral wire, that would be great.
a 2 port switch will be fine, just park the spare N in a wire nut and leave tucked in the back of the box.
the N will come in handy if at some point in the future you want to use a smart switch instead or a sensor switch.
@westward10 has made a good point, if in fact it is a 3 way switch then by following my instructions above, when someone operates the other switch that controls the light, the new switch you install will not work.
southeast Michigan
United States of America
Can I change this switch?
groston,
James,
