Hello
Is it OK to use a 32 amp rcbo on a radial Circuit. Cable size is 6mm2, cable length is about 15 m. There are 4 double plugs on the circuit. Loads are kettle 2.2 kw, washing machine max 2 kw, electric cooker 1 kw.
Cheers
I've only got 6mm2Op try 4mm cable better.
MK Sockets will accept 2 x 6mm no problem.Yeah you can but good luck getting 2 x 6mm conductors into the terminals
so will BG nexus.MK Sockets will accept 2 x 6mm no problem.
