Deleted member 26818
Well to be honest, that particular requirement seems to have been brought in as a knee jerk reaction.
No real thought has gone into it.
Should we allow a time limit, should there be a minimum temperature, should the item be designed to withstand fire only from within or also externally?
At present there is no requirement to retain any fire within the enclosure.
A whole raft of things which will need to be looked into.
A CU is a type tested DB and is used to distribut a supply into separate circuits.
Anything similar would have to do the same.
As such any device (such as an isolator, Henly block, switch fuse, up front RCD, etc.) which does not divide a supply into separate circuits would not be deemed similar.
However, a fire alarm panel could well be deemed as being similar.
