Search for tools and product advice,
Discuss Consumer unit upgrade with no slack on existing cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all,
As the title suggest, I have today replaced an old (1977) Wylex fuse board for a nice shiney 10 way consumer unit. However, when I took the old fuse board off the existing cables gave no slack, not even a smidge. They were solid and with just 200mm of cable left hanging out of the wall.
This was obviously not enough so I had to extend them to reach the new terminals in the new box. I have surprisingly not had this scenario for a very long time, so my dilemma now began. Do I use wago's, choc boxes or butt crimps? I opted for the crimps but also added heat shrinks to them as I did many years back when doing this. Probably a mistake, but I felt more comfortable with this despite the reliability of wago's.
Would you guys please let me know what you would have done given this scenario? A rewire was not an option before any comedians suggest it. ;)
Everything tested OK by the way. I'm just concerned about the longevity of crimps compared with wago's and choc boxes. They all come loose over time.
I had to extend a cooker circuit on my last CU change, used wagos for the 6mm twin and earth. the 3 pole red ones are good for upto 6mm and 40 or 41 amps. for the smaller sizes I tend to use the orange ideal inline connectors. not had a problem with them yet.
Arent those red ones just push in? You can't re-use them so they seem to be more permanent. I should perhaps read up more on them.
every time I go to some jobs ,I think to my self how do I solve this puzzle . .thinking to my self shall I ring a friend, no . I just get on with it .
...and if you were of a specific,religious persuasion,you'd have all those virgins to look forward to...;)
Arrangement in post 10 isn't good practice. The green/yellow DIN connectors connect electrically to the DIN rail, so the CPCs are all connected in parallel at that point, and won't be isolated from each other when disconnected from the earth bar in the CU for testing purposes.
If you do use an arrangement like this, use ordinary DIN connectors (same as used for the live and neutral wire), except for possibly the joiner used for the largest CPC, if you want to earth the rail.
View attachment 42036 If there's room I would of fitted an adaptable box with a din rail and din rail connectors. Mounted the new CU under neath and brought the extended circuits through. Like in this pic I've just found on google.
Nice only problem though is looking at it I’m assuming that the JB is plastic? Not really fitting with the spirit of the reg about metal Consumer units :tearsofjoy: in all seriousness though nice neat job:thumbsup: F**k I should really read the whole post before I open my mouth I only just went back and saw you post THAT I FOUND ON GOOGLE:rolleyes: Also why didn’t they just move the board up a bit in that situation seems like everything is coming in from the top anyway?
Nine times out of ten, when replacing a domestic consumer unit, it needs to be lowered to comply with accessibility recommendations.
AMD3 applies to consumer units and the like. No mention of materials for junction boxes.
Reply to Consumer unit upgrade with no slack on existing cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I had a consumer unit replacement today. It was a bit of a nightmare as most of the cables were too short for the new unit. I extended the ones...
6K
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
