Discuss Cooker - diversity. A second opinion would be nice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
6mm to kitchen.
Separate hob and oven. Rating combined just under 13000w
Am I right in applying diversity and the two appliances sharing the same supply.
45a dp switch off to two ccu's
32amp mcb 60898
6mm supply cable
T.i.a
6mm to kitchen.
32amp mcb 60898
6mm supply cable
T.i.a
Are you a real electrician?
Got no books to hand I'm away. Job is am tomorrow. So thought I'd ask as not done domestic in a while. Advise would be great as to confirm this is ok. I remember reading up about diversity for cooker supplies. Thanks. Don't be to hard on me please
Job done. thank you for advice telectrix. combined load was actually 10.10kw. upon install.
hob 5700kw
and oven 4400kw.
just thought id leave feedback !
yhat adds up to 10,100kW. you'd need Wylfa Nuclear Power Station to run that.
almost gave you a disagree there. how can there ever be too many beers?
Reply to Cooker - diversity. A second opinion would be nice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, I'm getting a 32a induction hob and a 13a oven installed as part of a kitchen refurb. The existing cooker circuit is 6mm protected by a...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
