Discuss Current being drawn on devices connected to power supply in the Electrical Tools and Products area at ElectriciansForums.net
Hi all,
Just wondered if there was any devices that plugged in line with the plug socket and plug which you can use to measure current being drawn on different devices being connected to a power supply? Just wondered if there was a better way then just using a multimeter.
Cheers,
Connor
Some of the smart plugs have power monitoring built in to them
Reply to Current being drawn on devices connected to power supply in the Electrical Tools and Products area at ElectriciansForums.net
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, I'm doing my Level 3 Electrical Install course, and I'm doing distance learning so most of the work is being done by myself with no guidance...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
