Search the forum,
Discuss Deactivating Optima XL4 house alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
E
ergolargo
Hello folks
Can anybody help me with a problem to do with a house alarm? I need to move the control box to allow space for some DIY work, and I want to turn the power off and deactivate the alarm just while the work gets done. It is an old Optima XL4. I have an engineering manual still, telling me the following info under the heading 'Power Up Reset - Clear NVM', which I'm giving here because I have a specific question about what happens half way through the procedure:
1) Remove the mains supply, and cause an alarm condition by removing the front cover.
2) Disconnect the battery. If self-contained, the external sounders will now operate.
3) Remove all wires from terminals 9(PA) and 19 (SET +).
4) Fit a wire link between terminals 9 and 19 and apply power.
5) The system will now power up with no alarm condition. Remove the wire link and replace the original wiring, checking that the ATTACK indicator goes off.
6) The indicators will now show in response to each of the zones and circuits as they operate. Refit the front cover, checking that that the TAMPER indicator goes off. When ALL of the zones and circuits become clear, the system will go to Day mode and at the moment, the NVM will be cleared and factory set conditions will apply.
7) The system may now be programmed, tested and recommissioned.
So ... I'm OK with most of this, but my questions are:
1) After 'the external sounders will now operate' in step (2), will these sirens stop sounding after step (4), or will they keep going until step (5)? In other words, could I keep the alarm in the disconnected condition at step (4), before 'apply power', while the work gets done, without the sirens going, and then complete the other steps when the room is ready?
2) Is there a better way to keep the unit disconnected from the power, without losing the NVM code for example?
Thanks very much if you could point me in the right direction with this one.
Regards
Hello folks
Regards
It's not clear why you are following the 'Power Up Reset - Clear NVM' when you don't want to clear the NVM
Hello
Unfortunately the procedure I quoted is the only one in the manual I have which includes removing the power supply. If there was a way of temporarily disconnecting the alarm without clearing the NVM, that would be good too, but the manual does include programming instructions in both 'customer' and 'engineer' modes, so I am not too worried about clearing the NVM, as I can reset it afterwards. But it would be easier not to lose it, therefore I thought I would include the second question too.
Cheers
PS Essentially the important question is, would the step 'Fit a wire link between terminals 9 and 19' stop the siren from sounding, or am I just stuck with the possibility of it continuing for the full duration (20 minutes etc.)
Disconnect supply, disconnect panel battery, SAB will sound (They rarely last 20 minutes)
Your done until ready to power back up, then follow procedures as per 1st power up.
the link has nothing to do with the soundes. it's inserted to rest the nvm. you have 3 choices.
1. dis power and battery and allow external sounder to sound till it either resets or goes flat.
2. get a ladder and dis the external sounder's battery
3. dis the mains supply ( safely) and leave the panel battery connected. this will hold the sounder off for several hours
just go bob the builder, power down, take front of, reset, undo screws holding panel to wall, put on floor, refit front, take off ear protection
Thanks for these ideas.
I'm thinking that there is no way to completely avoid the external siren going off, assuming that it will sound when I start to mess with the external housing. The problem I have with the control panel inside is that one of the screws holding the control panel into the wall is hidden behind the circuit board inside, so the control panel will need a bit of disassembling before I can take it off the wall.
How does this sound for a plan to:
* Minimize the duration of the external siren; and
* End up with the control panel not attached to any wall, but with the alarm still usable.
1. Remove fuse for control panel circuit to disconnect from mains.
2. Remove housing from external sounder housing - at this point will the siren will start going off?
3. Disconnect battery inside external sounder - at this point the siren will stop going off?
(3a. Remove ear protection!)
4. Remove front from control panel.
5. Disconnect battery inside control panel - will the internal siren go off at this stage, or is the alarm now totally off?
6. Unscrew circuit board.
7. Unscrew control panel from wall.
8. Replace circuit board.
9. Reconnect battery.
10. Replace front to control panel.
11. Replace fuse for control panel circuit.
12. Reset alarm on keypad if necessary.
If anybody can see a problem with this, or suggest an improvement for reducing the siren noises, I would be very grateful.
Cheers
Take the cover off the bell box first, only internal panel should sound (if SAB unit)
then just ditch mains & battery power.
When finished do reversal...panel will retain codes and program in NVM
Reply to Deactivating Optima XL4 house alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
