E
ergolargo
Hello folks
Can anybody help me with a problem to do with a house alarm? I need to move the control box to allow space for some DIY work, and I want to turn the power off and deactivate the alarm just while the work gets done. It is an old Optima XL4. I have an engineering manual still, telling me the following info under the heading 'Power Up Reset - Clear NVM', which I'm giving here because I have a specific question about what happens half way through the procedure:
1) Remove the mains supply, and cause an alarm condition by removing the front cover.
2) Disconnect the battery. If self-contained, the external sounders will now operate.
3) Remove all wires from terminals 9(PA) and 19 (SET +).
4) Fit a wire link between terminals 9 and 19 and apply power.
5) The system will now power up with no alarm condition. Remove the wire link and replace the original wiring, checking that the ATTACK indicator goes off.
6) The indicators will now show in response to each of the zones and circuits as they operate. Refit the front cover, checking that that the TAMPER indicator goes off. When ALL of the zones and circuits become clear, the system will go to Day mode and at the moment, the NVM will be cleared and factory set conditions will apply.
7) The system may now be programmed, tested and recommissioned.
So ... I'm OK with most of this, but my questions are:
1) After 'the external sounders will now operate' in step (2), will these sirens stop sounding after step (4), or will they keep going until step (5)? In other words, could I keep the alarm in the disconnected condition at step (4), before 'apply power', while the work gets done, without the sirens going, and then complete the other steps when the room is ready?
2) Is there a better way to keep the unit disconnected from the power, without losing the NVM code for example?
Thanks very much if you could point me in the right direction with this one.
Regards
Regards
