Hi, Defrost timer had stopped working and apparently part now obsolete. Cooling of fridge freezer still working and when manually advanced timer into defrost mode (7mins) defrost works but have to manually advance back into cooling mode (12hrs).
Anyhow i purchased the exact same internal capacitor and the mechanical timer started working and advancing. However when it clicks over into defrost mode, it defrosts but the mechanical timer stops. I can manually advance it into cooling and timer starts again advancing once again.
Terminal 1 which does not test as live when in cooling mode shows as live when in defrost. So my question is does something halt the timer (defrost terminator?) by sending a live to terminal 1 which feeds the capacitor if it is heavily frosted in the freezer? am i best manually defrosting freezer and see if this makes a differencefridge2.jpgfridge3.jpgf1773 pic3.jpgfridge 1.jpg
Seems to me you have connected the 4 connections wrongly. Draw me a picture and attach some photos.
I notice this freezer is old - 21 feb 2012 - 11 years ago. I'd buy a new one.
7 minute timer may or may not be obsolete, but a 10 minute version is definitely still available - I bought two last week, and have one of them beside me now. I doubt if the extra 3 minutes is going to make much difference.
Your fridge/freezer will work normally for a week, possibly more, but then the ice will build up on the evaporator and block the air circulation to the fridge, which will cause the fridge section to rise to room temperature.
Google dbzc-1210-1g6 , and pick a price you fancy.
You asked: So my question is does something halt the timer (defrost terminator?) by sending a live to terminal 1 which feeds the capacitor if it is heavily frosted in the freezer? am i best manually defrosting freezer and see if this makes a difference '
The answer is yes the motor for the timer is stopped temporarily by sending a live to terminal 1 when the single pole changeover contacts move from position 4(compressor run) to 2(defrost). See my diagram below. The live passes through the defrost stat (DFST). The motor M has a live on 1 and 3 so there is not potential difference across the motor to cause it to run - thus the mechanical timer stops.
What now happens in defrost mode is current passes from Line L through contacts 3-2 and the DFST to the defrost heater HTR. The compressor C has no power because contacts 3-4 are open. Over time the heater HTR warms up the evaporator and when the temperature exceeds 0C the ice and frost starts to melt and fall away. The heater remains turned on until the frost stat DFST detects the evaporator has exceeded 6C. With the compressor still unpowered the block of ice can only melt further and hopefully fall away from the evaporator.
Because the frost stat DFST has opened terminal 1 is now connected to Neutral N via the low resistance of the heater HTR. There is now a potential difference equal to the mains voltage across the motor M which starts to turn the timer mechanism. After a dwell of 7 minutes the contacts 3-2 open and 3-4 close which switches from defrost mode to compressor mode for cooling.
I hope you can see now that the voltage on terminal 1 will be live during the time the frost stat and 3-2 are both closed and low otherwise.
The key thing to note is that during heating the timer motor is stopped. How long the timer remains stopped depends on the power of the heater, the temperature of the ice and how much ice has accumulated. It is perfectly normal for the timer to be stopped while it waits for the frost stat to open at about 6C. I show this in my diagram as time duration x.
The 7 minutes dwell/delay after reaching 6C is to allow some time for heat to flow through the block of ice for the phase change from solid to liquid to happen ie the ice to melt and fall away.
The run time of 12 hours is an accumulated compressor run time not 12 consecutive hours. This is because the line input to the frost timer terminal 3 is via the freezer temperature control stat which of course cycles on and off. Thus even when contacts 3-4 are closed motor M only runs when the control stat is closed also.
If then the evaporator is very iced up it could take some time before you hear the timer motor to start up and implement the 7 minutes dwell/delay before resuming cooling.
Why did you think the capacitor needed replacing?
Might it be the evaporator was unusually heavily iced up and it is just taking much longer to melt and fall away. In which case you could manually defrost by turning off the power to the freezer completely and waiting for it to melt away. Then dry down evaporator and power up comletely again. Check drain hole is clear for melt water to clear away.
PS: Your timer is for a so-called Type 1 defrost wiring scheme which means motor M between 1 and 3. A Type 2 wiring scheme has motor M between 1 and 4.
@marconi I see what you're getting at - that he's connected the wires back incorrectly and has it switching off the power to the motor when it reaches the defrost start point, but these timers aren't known for their reliability, and they typically stall at that point when faulty, because that's where the heaviest load is applied - the ramp up the cam which operates the switch.
The timer in the link I supplied has the same connections as the one in the OP's pic. Motor 1 - 3. Switches 3 - 2 and 3 - 4.
@woodster Is there a wiring diagram somewhere on this fridge freezer, giving wiring colours?
Many thanks for this info.
We had manufacturer engineer visit to rectify fridge freezer. His conclusion was that defrost timer was faulty, but manufacture said part was obsolete. Having looked inside timer i could only assume the capictor was at fault or motor winding. took the chance on capictor and the new one when fitted the cogs started turning. However it advanced into defrost mode and as explained cogs then stopped turning.
i have since completed a manual defrost of freezer and then switched back on. Again timer cogs turned in cooling mode and fridge freezer working, but before it went into defrost mode the cogs stopped again, so unsure if still faulty.
Questions i have are: would the visiting engineer swapped over wires on defrost timer termials to enable fridge freezer to work only in cooling mode???? As per picture the wiring configuration is how i found them.
I have now sourced a exact same timer make , volts times etc, but worried if fitting will cause it harm.
To confuse things further i contacted manufacture explaining problems as per this posting and asking for wiring diagram. Only response i have had is that their technical team say the defrost timer should always be turning, and that a faulty defrost heater could be sending the power to terminal one
email reply from hoover candy
Our technical team have advised "The timer turns the heater on and continually carries on turning. Normally set to come on around every 8hrs. If defrost heater is faulty it will cause the timer to stop. This could be the heater is open circuit so that’s why the timer stops."
So i am at a loss with this now. Have asked that if defrost heater is available to get a manufacture engineer out to re look at problem and fit the new defrost timer.
Thank you for the update. I will study what you have said and get back to you.
Thanks, I cannot see any wiring diagram on or within fridge freezer. I have manufacture if wiring is correctly going to terminal. Problem is hoover candy took over baumatic brand and do not have all service/ spec information they have said
One way or another we will sort it out. Do you have a multimeter that can measure resistance? If not could you get one of these:
Compact Digital Multi Tester | Skytronic (600.102UK) - https://www.tlc-direct.co.uk/Products/TMMTB02.html?source=adwords&ad_position=&ad_id=&placement=&kw=&network=x&matchtype=&ad_type=pla&product_id=TMMTB02&product_partition_id=&campaign=shopping_excluded&version=finalurl_v3&gclid=Cj0KCQjwt_qgBhDFARIsABcDjOfjU-nu9xZpxOCmc-AHPLbhFOloNDDyl4lARYlcdp41AaBQhATyLXQaAtVPEALw_wcB
Amazon will do the exact same one. You should only spend up £10 on this model. I don't know if it comes with a battery. It uses a pp3 9V battery.
Yes
I have a multi meter. Just to add to the confusion there is no power to the timer on any terminal now???🤷 But cooling still seems to be working, but when advance manually to defrost it doesn't activate.
Please ignore my previous thread.
So I put back in the new capacitor into defrost timer and there was still now power at any terminals. So i left it a while and the cooling cycle kicked in and there was power to the cooling cycle terminals, and the defrost timer started turning. It clicked over to defrost mode , the timer stopped and power went to defrost terminals and terminal 1 which wasnt live. I waited must be half an hour as could hear freezer gurgling and defrosting, then the timer started again , and then 7 minutes later the cooling cycle started (fan and compressor). So it seems to be sorted. And it appears it was working before when i'd put in the new capacitor , but i just didnt understand who the components would halt the defrost timer and that the 7 minutes wasnt actually the defrost time.
It was your brilliant explanation that prompted me to leave the system a while and test your knowledge out. So many thanks for your help.
So for the cost of a £3 component ( and a new complete timer not needed at £33) it has saved this fridge freezer from going to recycling. Same the manufacture doesnt offer a simple cheap swap put of a capacitor when they say the defrost timer was obsolete, which it was not as i have one but had to wait a few week for it as it was on back order.
Oh yes you must tell her, that her hubby has indeed helped greatly. It is my 89 dad's and 87 year old mums fridge freezer, and mum cares for dad who has dementia. Due to this they could not get out to choose a new fridge freezer, so indeed your help is beyond thanks.
Tell your wife you have also done your bit for the environment, by saving the fridge freezer .
Your mother is a living saint. She will have a great reward in Heaven. Is/are she/they getting the support they may be/are entitled to? Don't answer to me but if no then you may wish to explore with Age UK and Dementia UK. Just google these charity names.
ng17 5hd
United Kingdom
Business Name
Engineering
defrost timer for fridge freezer
DIY Electrical Advice
Thread Tags
woodster,
marconi,
