Discuss Distributors Fuse Rating and Type in the UK Electrical Forum area at ElectriciansForums.net
E
electricphil
I know this topics is probably a very old chestnut, but how do I really find out what type and rating the distributors fuse is? The suppliers say its not their responsibiliy (EDF) and the distributor says they do not hold a database of the information. Its an old style fuse with no indication. I can guess that its 100A. Help!!
Whatever you do just be really careful, when you walk past the head, as sometimes these fuses have a tendency to fall out at the slightest vibration and then you have to push them back in gently
too true! :)
You have 3 choices:
1 Call the supplier for endless sessions on hold and no definitive answer
2 Record limitation or 'not verified' and a note that the suppliers fuse was sealed.
3 Ah, I can't quite remember 3 but it's similar to Malcolm's experiences!
i usually find drilling a 1/4" hole on hammer in adjacent masonry causes them to fall out.
Don't you just hate it when that happens, I now stick some insulation tape over the carrier mate .....................try and use some of that old red stuff, I find the new brown one don't hold properly
Can't have these fuses falling out now can we
Reply to Distributors Fuse Rating and Type in the UK Electrical Forum area at ElectriciansForums.net
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Hi guys, Rewired a unit where they make dentures, builder today has asked to install 16a commando socket with isolator (no problem) however...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
