S
stadlock1965
Existing dimmer switch wiring in attached picture. Hot and neutral in, ground wire, extra red wire that, I believe, carries the signal voltage. This controls a dimmable LED overhead light fixture with only hot and neutral wires.
I want to replace the dimmer with a normal, single pole light switch.
Can I and, if so, how would it be wired?
I'm stumped, quite frankly.
Thanks!
Thanks!
