Discuss DNO Cables Running Under Soffit Across Houses... in the UK Electrical Forum area at ElectriciansForums.net
OnlQQker
Just wondering what your thoughts are about this before I renew the facias/soffits/guttering.
Any help would be appreciated as it's my sons new house.
I've attached some pics
there nowt wrong about DNO lashing a cable to the house ,its better to have them strapped to the wall or a great big pylon in the garden ,are you going to stick the table and chairs to it and the brolly .get on with it .lol.
Are the cables visibly damaged or looking brittle?
if so report it as a safety concern to your electricity supplier.
Reply to DNO Cables Running Under Soffit Across Houses... in the UK Electrical Forum area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
