Red & Black on new stuff ,has a different meaning !
( for an economy in education )
Reactions: Rpa07
Quick job - isolate and remove the bathroom fan
Moving a socket 200mm to the left if you are a builder - how to join the cable in the wall before plastering it over.
To be fair, the actual joints had a bit of thin card to protect the joint from the plaster.
NB: The original cable is rubber, approx. 60 years old, and exposed basic insulation has become quite crumbly.
Found this at an outside light.
On the golf course this morning...
what is the IP rating of this assembly?
I think the JB might be ok, but the switch on a bit of plywood?
Still...it's Spain...
Definitely below par.
The sign says "Press Hooter", but there 2 of them...did someone censor this?
  • Funny
Reactions: DPG
At least it’s protected from uv exposure
unlike the top of my head, which looks like a huge Panic Button!
  • Funny
Reactions: Rpa07
What voltage is it operating at?
It's fed by a big blue cable that snakes away over the undergrowth...so I am assuming 230V as this is a common setup
On some holes, the warning is a good old-fashioned bell, with a clapper! Probably cos the cost of the cable was too much
Looks like it may be tee'd off the street lighting...
  • Funny
Reactions: Rpa07 and telectrix
Assumption is the root of all evils Pete
  • Agree
Reactions: chris gray
8K
Darkwood,
mainline,
