Yep 21 circuits reverse polarity. No seals on anything so I swapped them over obviously plenty of testing took place.
Did you also swear profusely after cutting yourself on the perfectly angled ends of the cable tie markers?
While we are on meters, found today. Clear identification:
At least it's an easy fix!
Really?!
You got to get fuse pulled…test…. disconnect from isolator… cut a couple inches off each tail and reterminate.
Torque driver for that, of course…
Then check for polarity… retest…..
This could take a whole day? sucks teeth
  • Funny
Reactions: pirate and DPG
Really?!
18V IMPACT DRIVER driver for that, of course…
Corrected for you
Impact drivers only for mcb’s, dusty…
Cutting tails with a pair if scissors as well, eh?
At least there wasn't any copper showing.
Reactions: SparkySy and DPG
I always leave a bout an inch of copper on show so the next bloke can get his test probes on it to test polarity🙃
No need to test on that installation the electrician had very thoughtfully marked the cable's. 😱
Callout yesterday to lights flickering and arcing sound in lounge light due to loose connections. Sorted that and wanted to do some tests/checks before I left, found this. Meter, cutout and 2 way(!) consumer unit for the house all mounted in a low level lounge cupboard. I only really found this as I had to move the customers stuff out of the cupboard to get at the CU. Wasn't about to leave that as it was so accessible and there were children in the house so I removed it and left an electrical danger notice explaining to the customer the urgent need to upgrade the earthing, bonding and RCD protection, and to have a full EICR carried out. Took a load of loop readings from the 2 circuits, highest was 0.41 ohms so I wasn't too bothered with the lack or RCD protection. Probably should have phoned EDF and kicked up an absolute stink but I didn't have time for that and 2014 was a long time ago. The sticker on the meter cover wasn't broken but the name information had been ripped off and the crimp seal was blank, presumably the meter fitter hiding their tracks. Perhaps regular EICRs should be encouraged more for non-rented properties.
Obviously lost its lower cover, did the owner have it somewhere? sort of thing you find on the floor and stick in a cupboard.
Reactions: DPG
What do you do if you decide to cut corners and realise your enclosure won’t take an armoured gland, but you need to earth the armour to your 2 core SWA?
Et voila 🙄🤦🏼‍♂️😂
I do despair sometimes with some of the things I see. I wouldn’t mind but it’s not even tight.
Seen this LOADS of time , done with an earth clamp or hose pipe clamp
I even witnessed a NIC sparks do this on site and he said it was an 'acceptable' solution to a problem 😬
IMO, that's about as acceptable as Rudolph pulling Santa's sleigh after a vindaloo.
8K
Darkwood,
mainline,
