telectrix ~ Mentor Arms Supporter Sep 5, 2010 71,498 72,015 18,688 78 cheshire/staffordshire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Electrical Engineer (Qualified) Business Name Telectrix Feb 16, 2013 #4 ton123 said: hi does earthing provide basic or fault protection Click to expand... what do you think?
telectrix ~ Mentor Arms Supporter Sep 5, 2010 71,498 72,015 18,688 78 cheshire/staffordshire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Electrical Engineer (Qualified) Business Name Telectrix Feb 16, 2013 #5 hmm. are you a trainee or qualified? answer. yes. good start.
G GLENNSPARK Feb 16, 2013 #6 ton123 said: hi does earthing provide basic or fault protection Click to expand... if you don`t know boy then look in a book... stop asking banal questions in here before researching...
telectrix ~ Mentor Arms Supporter Sep 5, 2010 71,498 72,015 18,688 78 cheshire/staffordshire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Electrical Engineer (Qualified) Business Name Telectrix Feb 16, 2013 #9 OK.do you have BS7671?
S Sintra Feb 16, 2013 #10 Have a look at this it should have everything you need to know. http://electrical.----------/wiring-matters/26/electric-shock.cfm?type=pdf Reactions: 1 person
