Discuss Dome light switch will only work with doors open cannot get to work with just the on switch in the Auto Electrician Forum area at ElectriciansForums.net
Brad-721
Hi I have a 2019 Toyota Landcruiser 79 series
Vdj79
My interior light only will work when doors open cannot get fit to work with just the on switch
I did trip the fuse when re wiring a new light and replaced the fuse but cannot find any other fuses blown or nothing
Why is there no power going through the wires when it’s switched onto the on
TL;DR
Help needed to get power to dome light and it not fuse
Normally you have to have a permanant positive and negative connection at the fitting for the light to work without the door open
That sounds like you are missing a wire at the light the switch would normally operate from the door switch in one position and from a permanant connection in the other position with a centre off position
Reply to Dome light switch will only work with doors open cannot get to work with just the on switch in the Auto Electrician Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
