Discuss don't use rcbos for TT in the UK Electrical Forum area at ElectriciansForums.net
Double pole isolation or switching on a TT system would be achieved by the main switch.
There is nothing wrong with installing single pole RCBOs on TT systems however if there was an s-type up front, you would need to install double pole RCBOs if RCBOs were specced for the job.
Why D ?
Most upfront S-types are DP/Multi-pole anyway, I have seen these double up as the Isolator too, in fact on the model forms there are boxes to fill in where the RCD is used as a mains switch.
Just curious to your reasoning as to why you would need DP RCBOs in the above scenario where an upfront DP or multipole S-type RCD is used.
N-E fault on the single pole RCBO protected circuit will take out the upstream type-s too. So much for minimising inconvenience in the event of a fault! lol
What they are trying to say is RCBOs are single pole and should not be used where double pole is required, They are not saying do not use on tt, why would they?Manufactors instruction leaflet states {on schneider electric rcbo)
Do not use on installations that require double pole switching eg IT or TT.
Think you'll find those RCBO's may well be SP+N rather than douple pole in the true sense of the meaning...
The description in the link states disconnection of both line and neutral upon tripping.
Never heard of this brand before. Interesting price too ! I might bear them in mind for the future.
SP+N is better than SP alone.
I’ve only got two RCBO’s in my flat, they’re coming out as soon as I get around to it.
I priced up Hager DP units, good job I was sat down when I saw the price. There’s bags of room in the board so a couple of MCB’s and a second RCD will be going in. It also means I can split the two rings between the two RCD’s. BTW it’s a 16[SUP]th[/SUP] board.
Before you ask, it’s how I found it when I moved in.
Oh dear Tony! Carrying out electrical work in a house without being NICEIC registered! Don't be suprised when the Part P police come a'knocking! A cowboy now as well as a Yorkshireman, it just keeps on getting better and better!![]()
but i am...and he rang me up asking if i`d do it for him....Oh dear Tony! Carrying out electrical work in a house without being NICEIC registered! Don't be suprised when the Part P police come a'knocking! A cowboy now as well as a Yorkshireman, it just keeps on getting better and better!![]()
which kind of blows geordie`s sly comment at #21 out of the water as well......:27:
oh so he told you did he?...More like Tony phoned your mother and she told you get round there and do it.![]()
only half the story as i was also told that if i didn`t i was to `get up them stairs without no tea`...
yeah...she has.I like your mother ... she has style.![]()
my style comes across loud n clear in my posts & replies...didn't do a good job of passing it on though. :24::tank:
Reply to don't use rcbos for TT in the UK Electrical Forum area at ElectriciansForums.net
