Discuss Drayton LP822 Once button results in permanent hot water in the Central Heating Systems area at ElectriciansForums.net
EddieB
Guys
Encountered a problem using the above function, when the once button is selected for a boost on the CH the Immersion heater will not then switch off. I have to switch the programmer of for it to reset... any ideas??
The boiler is an Ideal ICOS and the Tank controls are Range
Guys
Once will stay on until the last time its set to go off.
I suspect a y-plan? if it is more than likely a problem with HW off/satisfied side of the wiring or component failure of the programmer or cylinder thermostat. Work through the sequence of switching with your multi meter.
Reply to Drayton LP822 Once button results in permanent hot water in the Central Heating Systems area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi all, Yesterday I returned home to no hot water after a few days away. After a brief inspection it seems the fault lies with the Horstmann...
4K
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
