Discuss Driveway light in the UK Electrical Forum area at ElectriciansForums.net
Absolutely not. Plug tops are only designed to take flexible cords and nothing else. You could gland the armoured cable into the load side of a metal clad RCD spur.
Reply to Driveway light in the UK Electrical Forum area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
