Discuss Dusk to dawn lamp in the Lighting Forum area at ElectriciansForums.net
Rappid
Fitted a new outside light for customer and dusk to dawn lamp, the lamp keeps flashing off and on every 20 seconds.
Found the fault to be the reflection from the clear plastic housing is lighting up the photocell and causing the lamp to switch off, then in darkness the lamp switches on again.
The only solution I can thin off is either a miniature photocell I can hide somewhere or a timer that is a direct replacement for a light switch that will be compatible with LED lights.
Neither of which I can find.
Any other suggestions.
Thanks.
Thanks.
Have you put a LED lamp in or is the fitting itself LED?
Some of those type of lamps flash on/off a few times to acknowledge what setting its on. Not sure about every 20 seconds thou; is there nothing listed in the instruction book.
Is the sensor built in, if so where isit positioned, could you upload a photo? If the light output of the fitting is untriggering the photocell then the photocell sensor will need reloacting.
Fitted one of these GLS Sensor Lamps, Light Bulbs BC B22 ES E27 - https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lamps_and_Tubes_Index/GLS_Household_Sensor_Lamps/index.html. Customer said when they remove the clear plastic housing, the lamp stops flashing and when they put the cover back on, the lamp starts flashing again. I'm guessing the reflection from the housing is causing the photocell to think it's daylight and switch off
If the fault is the combination of the lamp and the fitting itself then swap it for a photocell fitting designed for the purpose.
Reply to Dusk to dawn lamp in the Lighting Forum area at ElectriciansForums.net
Hi all, I have a Malibu 120W Light timer for low voltage outdoor lights. When I manually set to ON, the lights go on, so I know the lights are...
Deleted member 147834
Customer wants a Dusk 'til Dawn only 50W+ flood light. Currently he has the normal stand alone photo cell with a standard LED flood but is...
Hi all, need to replace a failed 500w halogen PIR floodlight. This one was a dual output model that had an adjustable dimmer on the PIR housing...
I'm replacing a motion sensor for an outside light with a dawn to dusk one. Going into existing sensor 6 cables see pic. the dawn to dusk...
Hello everyone. Thank you in advance for any help you can provide. I tried installing a dimmer to a 3-way circuit. The dimmer has a hard...
