Discuss Earthing conduit in the Industrial Electricians' Talk area at ElectriciansForums.net
Y
YTSOxford
Hi all. Just a quick question for the more experience sparkies out there.
Haven't done alot of conduit work before, so am not sure babout bonding.
I'm helping to second fix a job and the builders have removed an internal wall, leaving a leg of the ring and shower cable.
Since the runs aren't in the zones of accessories or in the corners of the walls, I am sure they should be in earthed metal conduit. But where do I take the earth?? Does it go back to the MET or can it go to the earth terminal in one of the associated JBs in the roof space??
I would like to wait for one of the other sparks to do it, but if I know the builders, they will burried it the plaster, and foget about it......until the customer puts a picture up!!
Thanks.
Have you checked if theses circuits are RCD protected ? if so they dont need to be in metal earthed conduit .
HTH
If the cable is not in a prescribed zone then yes it needs to be in steel conduit and can be earthed via a local circuit jb in the loft.
Reply to Earthing conduit in the Industrial Electricians' Talk area at ElectriciansForums.net
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
I am going to need to install a small amount of galvanised steel conduit, leading down to perhaps 4 sockets and a light switch. This is in a...
4K
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
