ses
Interesting job doing a massive eicr on a factory
On a lot of the socket circuits the sockets are wired in singles in metallic trunking with the trunking being used as one of the cpc's it appears.
So two things are the trunking is also being used as cpc for lighting and some other circuits
And the drops from trunking to sockets are in plastic conduit with only one cpc in
Ideas on coding the above, can you use trunking to provide earthing for more than one circuit?
Also have quite a few boards and switchfuses fed direct from main switch incoming side i.e twinned with the incoming feed on another board coding ideas ?
