I'm not sure on this at the moment. If there was ill have to take cable reference methods into account
No loft, bedrooms, under the floor boards.
I have 5m insurance cover.
As it is an attached garage I assume the run of cable is fairly short, this should mean you will be within the Zs limits for the circuit but you would need to check beforehand by calculation based on the existing Zs at the lounge ceiling rose and your length of new cable (including the run to the switch).
If you are passing from the lounge into the garage you should be aware that this wall is a fire compartment wall and the fire rating of the wall should be maintained.
Cables passing through joists must be >50mm from the top and bottom of the joist to protect against inadvertent nailing.
There are a fair few things to be aware of in doing this work and it is useful where you have a friends house to work on that you take a good read of the relevant regulations and ensure that you are not missing any thing vital, the time taken will pay for itself int he long run by raising your awareness for future jobs.
Take care, read and apply the regulations, good luck.
GEelecs, Welcome to the forum.
Sorry but it seems you're been given a step by step guidance to your install and we don't consider this to be what the forum is for when you are potentially going to be paid for your work.
I would recommend you get employed as an Electricians mate for a few years to gain the essential experience needed to forward your career, jumping in the deep end then asking an internet forum how to do your job on this level is not the way to do it, we will not allow a post by post guide to help you do paid work, we are happy to help with the odd query regarding regulations as they can be a minefield of confusion but not a walk through.
You have been asked several questions that you hadn't even considered in your original post that are very relevant to the safety of the install, so please take the advice that has already been given and the questions asked as an eye opener.
PS- 5million insurance will only be covered if you can proof you understood and followed the regulations, if someone is injured or killed as a direct consequence of your install and you are found liable then it won't mean jack if you breached the regulations without good cause and safety in mind.
I'm Closing the thread on that note as I believe you have been offered more than enough advice and strongly suggest you gain experience with a competent person/company.
