Discuss Extending a lighting Circuit in the UK Electrical Forum area at ElectriciansForums.net
G
GEelecs
Hello All,
A friend of mine wants me to put lighting into his attached garage,
He wants 2 fluorescent tube lights (28W) putting in.
I have passed my domestic installer course and 17th edition course last year and I'm Part-P registered.
(I'm currently waiting to register with NAPIT and to be assessed on this circuit hopefully)
I have had a look at his house electrics.
Its a TN-C-S system with the old fuses. (Needs Updating Soon)
I'm sure I can spur off the lights in the living room into the garage but I cant exceed the current rating of the cable.
There are only 4 lights on the circuit each with 60 watt bulbs so 60 x 4 = 240w + 28w (268w)
268/230 = 1.2A.
The lights are wired with 1mm cable. (16A Clipped Direct)
Can I extend a circuit on a old fuse board? I'm sure I can :90:
Cheers
(Advice will be very much appreciated)
Hello All,
268/230 = 1.2A.
Cheers
you have to make sure the work you complete complies or exceeds the current regulations. Have you checked earthing and bonding arrangements are adequate?
I haven't had a look but could I come off the rose?
I had a look around the house there is no bonding to the gas or water but its an old install.
GS can you please only post once and not the same post 4 times, each post as to be approved due to you being a new member.
Sorry MOD, I wasn't sure how the forum worked, I was wondering where my posts went.
Yes, I will do that first before installing the new lighting circuit, I have noticed that the bonding for the supply seems like 10mm and not 16mm can I change this or do I have to get the board to do this?
No Drama it's just that your posts sit in a queue until a member of staff gets to them it's not that you're being ignored, Once you get to 6 posts there is no need to approve each one.
Bonding for the supply?
Thanks, I was going to check this in my 17th Regs.
So if I bond then take the lighting circuit off the rose or use a junction box.
All will be fine?
The old wire fuse board had no RCD because I'm extending a circuit is it mandatory to provide RCD?
Clipped direct ceiling level and into the attached garage lights will be mounted on the joists, so RCD is required.
Can I fit a RCD/RCBO to a old fuse board? (NOPE)
All is good then :)
1. Bonding
2. Rose Or Junction box to spur
3. No RCD required
4. Test & Inspect
5. Certificate
Did I Pass :)
Reply to Extending a lighting Circuit in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi all, I was thinking to add some lights like in the attached image, basically twin batten lights to my attic but i'm not familiar with strip...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
