Hi got fire alarm sounder beacon, call point and micro switch for when the door opens to wire,
Wire 2 core straight to call point this will be connection 1 for perm and connection 3 for load with neutrals in a wago then to beacon this has 4 terminals
T1 is beacon negative supply
T2 is sounder negative supply (COM)
T3 is positive supply in
T4 is negative supply out
T1+T2 are oV terminals so can link them out for micro switch?
So from call point to terminals 3+4 , And then micro switch for door is 2 core so when door opens sounder and beacon go off where would this connect to?
