Discuss Fire alarm Sounder wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi got fire alarm sounder beacon, call point and micro switch for when the door opens to wire,
Wire 2 core straight to call point this will be connection 1 for perm and connection 3 for load with neutrals in a wago then to beacon this has 4 terminals
T1 is beacon negative supply
T2 is sounder negative supply (COM)
T3 is positive supply in
T4 is negative supply out
T1+T2 are oV terminals so can link them out for micro switch?
So from call point to terminals 3+4 , And then micro switch for door is 2 core so when door opens sounder and beacon go off where would this connect to?
Quite a few assumptions here need to be cleared before i can help. You seem to have a Manual Call Point and switch? Why is the MCP needed? Is the MCP green?
Is the switch you mention monitoring the door for open and close? E.g. if door opens sound the sounder?
Is there a door magnet holding the door closed involved at all? Or other such mechanism, if so what voltage is it?
Reply to Fire alarm Sounder wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
Hello People Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO &...
I am doing renovation to a cafe in Scotland at the moment and after speaking to the local council the building requires the minimum standard for a...
