Discuss fire systems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
Thewiz
hi all,
just wondering as it's quite confusing as to what fore system (grade) are required for each property.
now .... we know that in domestic properties they require grade D in the hall ways and landing, all interlinked with battery back up.
now what about in a house turned in to two flats does this require a automatic alarm with a panel and detectors in the communal part and in the flat hall way.
hmo requires a full grade a system..... does anyone have a document that shows what to put and where???
I know it's dirrernt and many require risk assessments but there must be a general guide line.
Cheers
Hi
IT depends what insurance company require. I had the same problem. We called for fire assessment and I think is the best way.Accessor told me what I need to do and problem solved.
If you want any fire alarm guide just let me know.
Take a look in the resources part of the forum and you'll find that Sintra downloaded a guide to Fire systems that might be of help. All the best.
hi all,
Cheers
Many manufactures will assess and design for you.
When applying for a HMO licence the requirements and assessment will be supply by the local council.
Never start a HMO job without this application.
Reply to fire systems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
Now there's a requirement for a Fire detection in all bedrooms as well as hallways Lounge and Kitchens can the detectors be wired from the...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
