Discuss First Domestic CU - Pic Heavy in the UK Electrical Forum area at ElectriciansForums.net
S
SKY
Finally got around to changing over my consumer unit from a older Wylex single RCD unit to a new Dual RCD unit.
Will be using this install as my Elecsa Assessment on Monday.
My board is in the cupboard under the stairs.
Loving the snap in Crabtree busbar. I have seen this before in Ireland on a Siemens 3 phase board but first time I had seen it on a domestic.
Will fit Crabtree in future.
Old Board off and batten up
New Plasterboard with cut outs
Board Mounted
25mm Tails In
Ins Res Testing
End To End On Ring
Continuity Of Ring
Reading at sockets
End Of Day 1
Start of day 2
Lunch time day 2 - fitted a light in the cupboard on its own feed opposite to the ground lights side of the board.
So if that side goes you will still have light above the consumer unit
Batten up and plaster board in the cables
Finished - Just got to finish testing, cover up and label.
ZE
PFC
Have done lots of 3 phase Merlin boards in work on the shop floor but this is my first domestic.
On side 1 I have
1= Shower
2 = Down Ring
3 = Outside Socket
4 = Up Lights
5 = CU cupboard Light
Side 2
6 = Kitchen Ring
7 = Up Ring
8 = Boiler Radial
9 = Down Lights
good effort but a few points
1 the grey outer sheathing of the cables should enter the enclosure , which they dont in your pic
2 the neutrals have been cut a bit too short , no slack to reterminate at a later date.
and wood makes a more durable mounting surface than plasterboard.
keep at it though :)
Cheers for the feedback.
Had no choice on cable length as only a CU change preferred this than crimping.
The board screw into the backing wood behind the plasterboard.
it could be argued that the cable sheaths are inside an enclosure formed by the battens and plasterboard, though.
its a nice job to be fair,tho an emergency light fiting above the cu is always a nice touch to finish off,should be standard imo then you can kill the whole board and still have decent light to work in.
beaten by quick fingers rob by a minute
Thanks for the pics SKY.
Can we have some of the refurbed incomer?
Will do tomorrow when camera battery is juiced up again.
- - - Updated - - -
Now I have the feed there I may add a EML.
Plasterboard less flammable that wood!!!!! He he
Great thread SKY joking aside fair play for posting your work up for all & sundry to see .....and criticise
no !!
a wall void does not form part of an electrical enclosure.
detention for you after school tel .
bad , bad boy.
it's not a wall void. it's outside the wall.
- - - Updated - - -
no !!
bad , bad boy.
Reply to First Domestic CU - Pic Heavy in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
