Discuss Flashing LED Bulb in combined extractor unit in the Lighting Forum area at ElectriciansForums.net
jrm1991
Hello,
I have recently had a Led downright/ extractor fan combination unit installed. After approx 10 mins the light begins to flash intermittently (as attached). The bulb installed is a 3 watt bulb. I swapped this out to a 4 watt bulb and the flashing increased. The electrician whom installed has been out and replaced part of the light fitting but this hasn't resolved it. What could it be?
Cheers
Jamie
  • 20191013_131505.mp4
    10.8 MB
if the original lamp was halogen, then the driver/transformer is incompatible with LED. you need to get it replaced with a LED driver.
If I'm not very much mistaken, that looks like a Manrose LED Showerlite, and they don't normally do that. :)
If your electricians changed the driver, he needs to check his connections, might have live & neutral mixed up. Ask him/her to come back & rectify.
Reply to Flashing LED Bulb in combined extractor unit in the Lighting Forum area at ElectriciansForums.net
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
Hello to all. I know now that 1mm T&E would be better for lights, but legally is 0.75mm Flex in conduit behind tiles and tile backer sufficient...
Hi. I have an inverted spotlight above my shower and the light bulb has gone so need to replace the LED spotlight but I don’t know how to get into...
Hello All, My name is Tom and I know just enough about electrical work to be dangerous, thus I usually have a professional do the work. That...
I have several rooms of downlight fittings with non-dimmable 5W GU10 mains AC LED bulbs, making about 150W total. They run off a single 1.5mm twin...
