TheSirSpence
Hi, hopefully this is a quick one, in my new house I inherited a bathroom mirror with 4 small bulbs in it. This is hard wired to the main lightswitch.
When I first turned it on with new LED Bulbs I found that they were flickering. I took the mirror off the wall to see how they were wired. It seems that they are all wired in series. When I unscrew the last three bulbs, the first one stops flickering. I would be happy if they would dimmer to be honest because they're a bit bright.
Would rewiring them into parallel citcuits fix the issue or will the bulb simply not light up?
