Discuss Fused Spur and 1G 13A for double back-box? in the Australia area at ElectriciansForums.net
J
JohnGeddes
I have a project where I need to take a (fused) mains supply for an HVAC control box (in a village hall) without disturbing decor. The obvious answer would be to replace a 2G 13A socket (double backbox) with a combined double unit (or modular units fitting into a double faceplate) that provided a Fused Spur in place of 1G, leaving the user with 1G 13A still available. But I can't find anyone offering Fused Spur+1G 13A in a combined double-faceplate unit, nor can I find any modular system that would allow this.
Ideas, please.
John Geddes
One way would be a short legnth of 100x50 dado trunking mounted over the existing socket....into this you could fit a twin socket and FCU in the clip in boxes,and end caps to finish.Be neat and tidy.
Thanks for the suggestions, and so quickly!
The dual back-box would clearly allow mixing of any two single units - but only at the cost of knocking out more wall for the wider back-box. What I was looking for was a solution that DIDN'T involve risking damage to decor.
The trunking solution is one I will look at - but it is sad to have to contemplate surface-mounting when I have a recessed back-box that is theoretically big enough to accommodate both a fused spur and a 1G 13A if only somebody made a front-plate unit/module system in the right configuration.
John Geddes
If your careful you should be able to chop out the small bit needed without making any visible damage. The backbox that's there at the moment is not actually big enough to accommodate the two points.
AC Guys dont like Plugs Richard as they can be pulled out and not plugged back in
Dual box would be way to go if your good you shouldnt damage decoration while digging out even if you do it will only be small bit
It's not so much cutting out a small bit for a dual back box that will result in damage,it's getting the existing double box out....if there are flush cables into a KO the box has to be tilted to come out....which means a bigger hole.
This is a much worse solution, but you could set the HVAC control up as a spur from the double socket with an inline fuseholder either in the socket or the control box, I am not sure this would meet requirements for accessibility or identification but would fuse the supply.
This is not a good idea.
Reply to Fused Spur and 1G 13A for double back-box? in the Australia area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
I'm sure this has been asked before, but I just want to confirm: Currently I have a spur leaving a socket in the bedroom, into a 13A Switched...
I recently came across some legacy lights which were taken off an un-fused spur which is part of a dual plug socket box. I have been unable to...
7K
  • Locked
united kingdom...yorkshire I rent a semi detached house out which was built 1970's With the tenancy just changed i thought i would change the...
4K
