Discuss Garden lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is any of the cable buried.
I tend to use H05 cable in conduit and copex, it's rated for outdoor use.
Flex trailed over a flower bed sounds like an absolute lash up. I wouldn't be trying to lessen the risk of impact on these cables through enhanced or additional protection, but thinking about redesigning the install so that trailing surface cables can be avoided. Section 714 also applies.
By flexible do you mean copex?
I agree, garden lighting is always a pain in the proverbial. Can't you drop the job and do a nice Couple of CU changes instead? Oops that sounded a bit sarcy, honestly, they are usually more trouble than they are worth.Flex trailed over a flower bed sounds like an absolute lash up. I wouldn't be trying to lessen the risk of impact on these cables through enhanced or additional protection, but thinking about redesigning the install so that trailing surface cables can be avoided. Section 714 also applies.
Reply to Garden lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
