Discuss Halide lamps compatible with sodium control gear in the Australia area at ElectriciansForums.net
Amp David
Mentor
Just been looking at some metal halide lamps that are made to fit into sodium lowbay fittings. Are they as reliable as using the correct lamp the control gear is designed for?
Never had experience of them before so don't want to advise of using them then find they're no good.:icon11:
Reply to Halide lamps compatible with sodium control gear in the Australia area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
I have a ceiling fan which currently has a remote control for fan speed and dimming the attached lights. We're currently doing some works in the...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I'm doing a job which needs LED tape under shelving, 6 shelves with ~1.2m of RGBWW tape under. I've used downlightsdirect and downlights.co.uk...
