Feb 23, 2010
23
20-22 Wenlock Road, London N1 7GU
www.toplightco.com
Manufacturer / Distributor / Supplier / Inventor - etc
Business Name
Toplightco Ltd
I've been asked to quote for track lighting replacement in a London art gallery that's suffered extensive water damage from the floor above. Quoting for the track and CRI90+ tracklights is not a problem for us, that's what we do.
The problem is they want us to quote for the additional lighting which is controlled by a wired Lutron dimmable system from various different wall switches. Assuming the Lutron wiring checks out ok, I am wondering what kind of LED Drivers will need to be used for the new lights. I'm thinking maybe 1-10v dimmers but I'm unsure.
Any help would be appreciated! Bear in mind that I'm only talking supply - you guys do the installation! Thanks
TL;DR
Lutron wired system - what LED Drivers to use for dimming?
I think a call to Lutron's technical support team is probably the best place to start, it may well be different depending on what units are installed on the premises and possibly even the way they are configured.
they should be able to point you in the right direction.
Website
https://www.toplightco.com
Business Name
Toplightco Ltd
Help retro fitting lighting on old Lutron system from 2007
Lighting Forum
toplightco,
James,
